Monitoring software builds with a traffic light
[JD] at isotope11 was looking for a way to get instant feedback whenever a developer broke a piece of software they were working on. After finding a 48 inch tall traffic light, he knew what he had to do. Now, the entire development team knows the status of their code from a traffic light hanging in the corner.
isotope11 runs a continuous integration server to do the quality assurance on their software projects. It’s a lot more flexible than the ‘compile and pray’ setup we’re used to, but then again C isn’t very well suited to test-driven development. When one of [JD]’s developers breaks a piece of code, the CI server will send a warning to an Arduino where all the electronic magic happens.
To light the traffic light, [JD] used a few relays to drive the 120 volt bulbs in the traffic light. The traffic light is very easy to read – red means something is broken, green means everything is alright, and yellow means a test suite is being run.
Check out the video of [JD]’s TDD visualization after the break.
[youtube=http://www.youtube.com/watch?v=3T5fEV5YHYo#!&w=470]
  1. jim says:
    um is that one of those hollywood filmset lights with different colours so it comes out normal in postproduction? am i stoned?
  2. Cristi Neagu says:
    You should have a big buzzer going off when a project fails.
  3. Munch says:
    C isn’t well-suited to TDD? What crack are you smoking? I’ve been doing TDD with C since 1998. C.f. http://www.falvotech.com/content/cut/2.6/
  4. Denbo says:
    Very cool project but tell the camera guy not to chew gum next time. Kind of a distraction
  5. blah says:
    Cool, but pointless, if you have that monitor showing the project red, the stop light is redundant lol.
  6. Josh Adams says:
    Josh from Isotope11 here. We do not always run the wall display on that monitor. Hence, !useless
  7. jim says:
    well, ok, but shirley something a but smaller would have done. maybe a little train that carries messages on its carriages?
    you could have it automatically order them in a shunting yard to construct sentences? i am sure this could work
    • notmyfault2000 says:
      And then automatically deliver the message to the guy that broke the build!
      Oh overengineering, is there any problem who’s solution you can’t make more awesome?
    • kb says:
      “well, ok, but shirley something a but smaller would have done. ”
      And stop calling me Surely.
  8. johndavid400 says:
    well… actually in the original design, there was no “Traffic light” there was a “Taser in your seat”, and anytime a developer broke a build – they would be the first to know it. But we soon realized that we would never have anyone deploy any code, so we went with “Traffic light”
  9. astro73 says:
    The local dev firm Atomic Object does this exactly. Except they’re a Ruby shop.
  10. N0LKK says:
    Only adults have to invent a reason to play, and justify it by making it look like the result is going to make things more productive. 😉
  11. xargle says:
    Gum chewing camera man is quite disgusting.
  12. Mike says:
    We did this with red and blue lava lamps at work.
  13. Tom Robinson says:
  14. Someone says:
    This is a pretty old thing.
    GitHub did this almost 2 years ago:
    http://urbanhonking.com/ideasfordozens/2010/05/19/the_github_stoplight/
Leave a Reply to notmyfault2000 Cancel reply
