A.R.T. sorts your recyclables for you
[Yuhin Wu] wrote in to let us know about the Automated Recycling Sorter that was built with a group of classmates at the University of Toronto. They entered it the school’s student design contest and we’re happy to report that it took first place.
The angled sled has been designed to separate glass, plastic, and metal containers. The first sorting happens at the intake area. A set of moment armsΒ are used to weed out the glass bottles. Since there are several of them in a row, a larger and heavier plastic container will not be falsely sorted and the same goes for smaller glass bottles.
With the glass out of the mix the team goes on to separate metal and plastic. An Arduino was used for this purpose. It senses an electrical disturbance caused by a metal can passing through the chute and actuates a trap door to sort it. Plastic has no effect on this sensor and slides past the trap to its own sorting bin.
Don’t miss both demo videos which we’ve included after the break.
[youtube=http://www.youtube.com/watch?v=6V8QCOc4pq0&w=470]
[youtube=http://www.youtube.com/watch?v=_BJrog8neR4&w=470]
  1. polossatik says:
    the hard part would be to make it usable in “real life”,
    but +1 for all people trying to figure out things.
    • Tony says:
      This is how it done in real life, recycling places really need to put up more videos on YouTube.
      They use a lot of tricks to separate out stuff, the obvious one is magnets to pull out steel, but also optical, weighing, eddy currents, resistance etc.
      Quite impressive when you thing about it.
      • polossatik says:
        yeah, I should have been more clear.
        I mean more like “make it work fine if you just clear out a container of mixed stuff at once”
        I bet the real nitty gritty stuff is in figuring out that part πŸ™‚
  2. Mr. Coffee says:
    I hate to be so negative but sorting glass by weight isn’t the that reliable, primarily because it needs a mechanical size check. I also question the scalability and cost versus cheap labor.
    • Kevin says:
      Seems to me that the size/weight part was taken care of by the “set” of moment arms. Scalability? well, at this scale, it’s a cheap solution for home sorting, when you have lazy people or kids and curbside recycling is required.
      At large scale, similar machines are already used, controlled by multiple computers, with people involved to pull out other trash and stuff that gets missed. They just cost a huge amount and sort a huge amount. This is a scale down, the large scale has already been done. In particular I see this at this size as a good idea for cities where curbside recycling requires people to sort the recyclables into multiple bins. Some people, or their kids will just dump whatever into whatever bin.
  3. gizmoguyar says:
    I don’t like to dissent, but I do hold the big picture in mind. For this to be practical it would also need to be able to sort paper. Also if you have to put one piece in at a time why not just have three bins sitting next to each other and place it in it’s respective bin?
    • Mike says:
      Seriously? Who made any claims about its scalability, or even suggested market? Do you know the scope of the contest they built it for? As they were awarded first place, do you not think being scalable to an industry level wasn’t a requirement?
      The negative Nancys of HAD are undoubtedly a reason less people are willing to share their work here. It’s called hack a day, not production ready product a day.
      • Cody says:
        Well said Mike! It’s clearly indicated that this was done as part of a student engineering competition. Maybe the naysayers should try offering constructive criticism and productive suggestions instead of criticizing for its’ own sake (or to see their name on screen). These young people developed a relatively simple solution to an everyday problem and demonstrated that it can be done which , I’d venture, was the objective of said competition. Give them a little credit for their accomplishment. (Steps down, picks up soapbox, and exits… )
  4. Bob D says:
    Not perfect but a great project!
    I’ll think about it every time I’m at a coffee shop with Recycle, Compost and Trash bins and notice that the contents of each is exactly the same.
  5. fartface says:
    Most waste companies already have this and do this. Here in michigan we have waste stream recycling, so you throw everything in the trash and they have automated systems to pull out metals and plastic.
    these kids invented something that has existed for years in the Industrial world.
    • TacoStand says:
      You realize you’re talking about a science fair project, right? They weren’t trying to revolutionize the recycling industry.
      • Wm_Atl says:
        You are right. This is like many projects I did as an EE student. The professor creates a easily understood problem and we would create solutions that demonstrated that we could apply what the class was teaching. They came up with a solution and it worked for them. Nice Job.
    • I suppose these kids should never solved the classic projectile problem in physics since, well, that problem has been solved for decades.
      I suppose these kids should never use the test to type their own blood if they know it because, well, they’ve known it for years.
      I suppose they should never run a small scale distillation column to separate alcohol and water because, well, it’s been done for years in industry.
      There’s nothing wrong with doing stuff like this. As someone who deals daily with materials handling on a professional basis, I can tell you that they probably gained many times more knowledge that if they just read about how this stuff works.
    • Yuhin Wu says:
      First I would like to say that the mechanisms for separating the recyclables are original ideas thought up by me or my team mates. We are a team of mechanical engineering students from the University of Toronto, class of 2014.
      The original problem statement was to sort 3 distinct bottles. I wanted to go beyond that. Our sorter will sort bottles independent of geometry and color.
      I have never seen anything similar to our moment arm system for separating glass. The usual approach is to use a weighted door. Is our moment arm approach fool proof? No. If somebody drops a full can then the fingers will still articulate even though the can is aluminum and not glass. That was out of the scope of the problem statement and realistically does not happen often enough to be a problem. In addition, it can be solved quite easily by having a weight transducer before the moment arms. I am confident that the upper limits for an empty glass bottle is nowhere near the lower limits of a full aluminum can or plastic bottle.
      The industrial approach to isolating metals is to use eddy currents. This was too complex for us to fabricate in a reasonable amount of time and would consume a lot of power to operate. I believe our approach to sorting aluminum/plastic using an electric field is novel from a brief search on google. The usual mechanism is to use light for separation. Obviously using light has drawbacks as not all plastic bottles are translucent.
      If I was not a poor/cheap engineering student then I would still use our contraption. Unfortunately, I took the arduino out and sold it to recuperate some money. Maybe one day I’ll program an ATTiny85 to act as the controller.
      You are correct that industries have been utilizing recycling sorters for many years. You are wrong in saying we have merely recreated what they use industry. As per my points above, our ideas and approaches are completely novel.
      Feel free to contact me, mecheng4130[at]hotmail[dot]com.
    • Eirinn says:
      You don’t get nerd points for stating the obvious fartface. You do get a slap on the cheek for not seeing the big picture πŸ™‚
  6. Miroslav says:
    Well done. Now to scale it up so Toronto trash doesn’t need to be sent to USA.
  7. Hirudinea says:
    Seems like a waste of time to me, I don’t recycle anyway, I just burn all my trash in the back yard, throw on some old tires and gasoline and it works great.
  8. Bill says:
    Haha, nice. Reminds me of my senior design project, a robot that had to autonomously find, collect and sort recyclables.
    http://www.youtube.com/watch?v=QpEDXo-Rw_c
  9. robomonkey says:
    I have a carbon based unit that does the same thing…..ME! Some things don’t need a solution, just a bit of consideration!
    Not to undermine the effort though….nothing wrong with trying to fix a problem. But some problems need to not exist in the first place!
  10. Mikey says:
    I like this, but really, glass drops the farthest? That’s just silly.
Leave a Reply to polossatik Cancel reply
Related Hacks in green hacks
