A simple project to get you started with the Android ADK
simple-adk-exercise
If you just got your hands on a shiny new Android phone and are looking for a fun project to try out, you might want to check out this simple Arduino exercise that [Mike Mitchel] put together. Everyone needs a starting off point for hacking, and [Mike] thought that combining and Arduino and Android handset together for the purpose of temperature sensing and light metering would be a great place to begin.
The prerequisites for this project are a bit beyond a simple breadboard and a few ICs, requiring an $80 Android ADK board to go along with your phone and Arduino. If your focus is going to be on interfacing your phone with microcontrollers however, itโ€™s purchase youโ€™ll make sooner than later anyhow.
The setup is pretty simple as you might expect. A photocell and TMP36 temperature sensor are connected to the Arduino, then with a bit of code and USB host magic, the Android app shows the temp and amount ambient light present in the room.
[Mike] has made all of his easy to read and well commented code available online, so be sure to check it out if you have been thinking about (but putting off) playing around with the Android ADK.
  1. Lucario says:
    I’d do this kind of stuff but my ADK came with a “TinkerKit!” Shield and i cant find diddly squat on it. :<
  2. Conner says:
    You should have embedded the video!
  3. Robot says:
    What is the difference between the ADK boards linked in the article and the IOIO for Android?
    – Robot
  4. Android phones/tablets/media players are so cheap at dx.com that maybe it is time to start using them as user interfaces to our projects. I mean, glue one to your project and have touch screen UI with graphics display.. ๐Ÿ™‚
  5. Jason says:
    Amazon has the Arduino MEGA ADK board for $70 w/ free shipping
  6. casainho says:
    Android are a kind of “Ardunio” of the Smartphones ๐Ÿ™‚
    I am using cheap ($6) Bluetooth serial modules with my hardware boards and Android ๐Ÿ™‚
  7. kslauszus says:
    Alternatively you could just buy a USB Host Shield (http://www.circuitsathome.com/products-page/arduino-shields/usb-host-shield-2-0-for-arduino) if you already own an Arduino. It’s only 25$ – way cheeper than an Arduino ADK.
Leave a Reply to Tommi Rouvali Cancel reply
