Make your RC car drive itself with this simple brain swap
arduino-rc-conversion
If the kids have lost interest in that RC car or truck you bought them over the holidays, [Randy Sarafan] from Instructables has a few ideas that might help make the toys fun again, while teaching your kids a bit about electronics in the process. In his writeup, he shows how to swap out the brains of your run of the mill RC truck, enabling it to do far more than was originally intended. The procedure is pretty simple, and something that you can easily involve your kids in, if you’d like.
He uses an Arduino and a motor shield to keep the conversion simple, but this can be done with just about any capable microcontroller you might have on hand. [Randy] added a Parallax Ping sensor to the front of the truck enabling it to avoid objects as it drives itself, but since he cut out the truck’s original control board we’re assuming that there’s no way to override the truck’s actions at present.
[Randy] calls the conversion a “robot” though it seems like more of a semi-autonomous rover if you ask us. Regardless, revamping an old RC car is certainly far better than letting it collect dust on a shelf, or worse, tossing it out during spring cleaning.
Continue reading to see a short video of [Randy’s] RC truck in action.
[via HackedGadgets]
[youtube=http://www.youtube.com/watch?feature=player_embedded&v=Wn3Le37qW64&w=470]
  1. Dino says:
    Just looking at the pic makes me want to build a scale model PING that’s four feet long and mount it to the front of my BMW, then drive around town pulling up to walls, stopping, then backing up. lol
    Hacked toys are awesome and fun to build. Nice work.
  2. Oscar says:
    A semi-autonomous rover IS a robot you silly goose.
  3. buzzkil11 says:
    Why is this any less a robot than say, a battle bot which is nothing more than an R/C car with “accessories”? You have 2 axis control and at least 1 sensor. I have seen less than this labeled as a robot.
  4. Indyaner says:
    He calls it a robot, you a semi-autonomous rover, I call it a RC-Car that can drive back and forth without a remote to steer.
  5. conundrum says:
    Nice, I have a car here with broken remote.
    Stupid roof leaked and watered the R/C unit..
    Would be an amusing hack to mount an R101 on there with hacked firmware, and some Raspberry-Pi to control the wheels etc.
    Plus if the wifi drops out it can “phone home” with 3G/Edge to let you know its location and battery state etc.
    • rasz says:
      ? are you one of the 10 suckers that paid 1000 dollars for a numbered beta board? because to date those 10 are the ONLY Raspberry-Pi that shipped
      There is no point in even considering vaporware.
  6. Ren says:
    Now that SWMBette (daughter of She Who Must Be Obeyed) has her own RC car, I can get back to hacking my 4wd RC truck. Last year I bungee strapped a video recorder to it and made a motion sickness inducing video.
  7. kevin mcguigan says:
    why instructables?
  8. dbear says:
    Most cheap radio controlled cars have a motor driver chip on them somewhere. The two or three I’ve seen use the same chip. The inputs to the chip are TTL level and can be driven directly from the output of the micro you want to control them with thus rendering the motor control shield unnecessary. Great start for a robot platform though.
  9. conundrum says:
    @rasz Now now, just because they had one little production SNAFU..
    i’d have Epoxied over the LAN port and sent them out anyway, they are perfectly useable without it.
    Plus its easily reversed if needed when the new boards are available.
Leave a Reply to Indyaner Cancel reply
Related Hacks in toy hacks
