Becoming the YouTube loading animation
Whether you’re used to dropped wifi connections, or your housemates are using up all the bandwidth for streaming, we’ve all see the spinning octet of disks that is the YouTube loading animation. [technocrat] thought it would be a great idea to actually become YouTube and set out on designing a physical manifestation of the loading animation.
[technocrat] used eight ping-pong balls as the main structure of the build. After drilling each ping-pong ball and gluing white LEDs in, the only thing left was to connect everything up to an Arduino. The code loops through each LED and provides the ‘light trail’ animation YouTube has burned into our memory.
To complete the build, [technocrat] attached his physical loading animation to a black t-shirt emblazoned with the YouTube logo to make everything more understandable. While it may not be as colorful as the beachball of deathΒ or as conceptual as the Windows ‘spinning hourglass’, we’re really liking this build. Check out the video after the break.
[vimeo=38217006]
  1. HackJack says:
    First.
    Ownage! This rocks. I want to buy a kit. Thanks
  2. ino says:
    An arduino to shift 8 bits ? Come on !
    A single 8 bits shift register, a couple of logic gates (or an OP amp) as a improvised clock, and some capacitors for the dimming effect and there you go!
    • jaqen says:
      please make a vid of that πŸ™‚
    • juice says:
      Or just a 4017.
    • chango says:
      Okay Rockefeller, you go throw your expensive logic ICs at this problem. Why don’t you simply use a dekatron and line frequency?
    • BlackCow says:
      Couldn’t agree more. Expensive microcontrollers should ONLY be used if you need to do some processing of data. If you insist on using a uC to perform a simple task like this at least use a cheap PIC micro or something.
    • F4R4D4Y.dc414 says:
      I know. Why is it that most any project at HaD starts with an Arduino? It’s like the father in My Big Fat Greek Wedding spraying Windex (Fantastic?) on everything.
      Here’s a novel idea: Instead of duplicating the trails with PWM and LEDs, use incandescent bulbs. They get bright enough fast enough, and will “trail” as they cool.
      If you’re man enough to be YouTube, you’re man enough to take the tiny bit of heat behind it as well.
      Side note; I give it three days MAX before someone takes this past the loading screen and has YT on a shirt and it gets posted on HaD.
      • nikescar says:
        With all the people bitching about arduinos and touting their own knowledge you wouldn’t think that’d be the case. Then again, bitching is always easier that actually doing something. STFU. All of you.
    • radiowave911 says:
      It’s not just shifting bits – it looks like it is alo changing the intensity of the LEDs, to give the ‘tail’ effect seen in the YT spinner. I counted at least 4 difernt brightness levels. LEDs do not have the ‘fade’ that you see in the video of it working – when turned off, they are no longer emitting light, period.
      • ino says:
        So you think they used micro controller to do the K2000 effect ?! It’s the ” capacitors” I was talking about that do the job by sourcing some current to each led when they are not powered anymore.
        It’s simple electronic and it has been done for decades. ” period “
    • Nardella says:
      @imo The Arduino is in some ways overkill for this project. But in another sense “A shift register, a couple of logic gates (or an OP amp) some capacitors” can in a way be considered overkill.
      How much experience, knowledge and reading would a person have had to do to come to the solution that you suggest?
      Also, how much planning, math and problem solving would be required to complete this project with your solution?
      How big an inventory of parts would a person need before they could be expected to have all these parts on hand?
      How many single parts would be required for your solution? This one needs 8 LEDS, 8 resistors and an Arduino.
      How many connections would need to be soldered, are all the parts you listed available in non SMD versions?
      How would you power your version, I bet that would add at least a little complexity over someone who already has a battery pack for their arduino.
      @deathventure an Arduino can be had for 17$ (after shipping!)
    • War_Spigot says:
      Shift registers? opamps? logic gates? Back in MY day, we doped our own silicon and made our own transistors. Go and buy some capacitors? We had to make ours with a piece of paper and iron we got from the ground. AND WE LIKED IT! But seriously, why are half of the comments on HaD something along the lines of “Using a [insert device here] was way overkill. You should have just…” or “Arduino?! I Hate Arduino a Day!” If you don’t like it, don’t come to the site and don’t waste your time commenting. Just go make it yourself.
    • patman2700 says:
      Ok, let’s say you were to make this loading logo your way. Would you be able to, say, have it light up when you receive a Twitter update? How about when somebody opens your front door? At every half-hour, perhaps?
      Of course, there are ways to build this using discrete components – sure, it might show off your “geek cred”. That would NOT, however, be scaleable, hackable, expandable, modifiable, or user-friendly to those who do not know how to use shift registers (much less those who don’t even know what one is!). This attitude towards hackers and builders is what is keeping the craft in the dark corners of nerds’ basements, away from the public eye. The Arduino, for example, makes it easy and intuitive to not only implement an idea quickly, but also do so in a fashion consistent with those who would adapt it to other platforms, etc.
      (P.S. – Before I start a flame war: I have, in fact, built analog circuits without the Arduino, as well as designed machines that use the Arduino.)
      • Galane says:
        But it would be a lot cheaper. Using an Arduino for everything is like driving tacks and picking your teeth with a sledgehammer.
        Modify a simple “larson scanner” circuit to only go one way instead of reversing directions.
    • edonovan says:
      can I see your schematic and BOM?
      and once you are done building it, add a feature to allow selectable patterns.
    • technepoiesis says:
      It’a a nice visual effect and good practice using Arduino, soldering and many other Maker skills.
  3. LP says:
  4. Japala says:
  5. Harvie.CZ says:
    It’s true that youtube is terribly overloaded… I thought that i have slow internet connection, but now i am on fiber and loading is still slow… πŸ™
    • M4CGYV3R says:
      That’s interesting!
      I’m running on a cell phone tether and I’ve never had a problem loading YT vids. Maybe if you set the default quality to less than HD it will come closer to satisfying your instant gratification?
      • Alex says:
        I think it depends on the video you’re watching. In my experience, popular videos (like things in the gopro channel, for instance) load very quickly, even in full HD. Old/unpopular videos, however, load slowly and stall.
      • n0lkk says:
        For myself the buffering still exists, even if I select a lower quality. Not really about instant gratification, so bad, it should be illegal to use any term to describe the service, that suggests you will see “moving pictures” But it’s free they can say anything they want about it. The only up side is the hilarious still pictures you will see when it buffers.
    • Marco says:
      Consider using a different browser. I get vastly different video speeds with Firefox vs. Chrome.
  6. Niklas says:
    Constant Dullaart has done this already a few years ago and called it “Youtube as a sculpture”: http://www.youtube.com/watch?v=yGvWL7Vb7I8
    He also did this ultra lowtech version which is so stupid that I just love it:
    http://www.youtube.com/watch?v=ixMbZAqRTh4&list=UUyKmkdfB0xSKjEBlO_WHhkA
  7. alxy says:
    No snake game? πŸ˜‰
  8. localroger says:
    Using an Arduino to do this is like driving to the end of your own driveway to check the mailbox.
    • moo says:
      Wait am I the only one that does that?
    • Haku says:
      Didn’t one of the new weird neighbours do that with the trash in “The ‘Burbs”?
    • Dosbomber says:
      Depends on your driveway… mine is pretty long.
      Yeah, this guy [could have]/[should have] used a 555 and a 4017, or maybe a cheap PIC, but at least he’s doing something interesting. Not marketable, but I bet he learned a few things in the process, and that’s the most important part, as far as I’m concerned.
    • n0lkk says:
      Your not rural are you? For some driving to the end of the driveway to check for mail is somewhat common
    • n0lkk says:
      Be OK on a cap, but more than I’d put on a T shirt, but my T shirts are unadorned Anyway. I always figured YouTube was throttling us with slower connections to give the faster connections priority. I’m paying for a 1.5M/512K wireless wimax connection, and speeds tests show I get that or better most times. I could pay for more, but it wouldn’t help when the web is slower than my connection. Generally I start downloading what I want, and go do something else.
    • pRoFlT says:
      I used to drive to the bottom of the driveway to take out the trash. Then again my driveway was 1/4 mile long.
  9. rue_mohr says:
    thats funny, that non-youtube video completely dosn’t work on my machine.
    • M4CGYV3R says:
      Ditto. Vimeo embed player is completely borked, and has been for years. I’m surprised if it shows up for anyone.
      • Haku says:
        It works on all my machines here, except Vimeo appear to use a more processor intensive compression codec so the playback is often more slideshow-like on my Eee PCs.
      • Keith says:
        Glad to hear/know that my machine is not the only one that has this problem. I keep both FF and IE open at all times and have to use both due to things like this …
      • Malikaii says:
        @ Keith: There is an “IE Tab” add-on for FF that you may be interested in. It has worked well for me.
  10. Max says:
    Or, take a large transparent disk (perspex maybe) and some varying translucency disks (different thicknesses of tissue papers cut into circles).
    Drill a hole in the middle of the big disk and stick the other disks with their circumferences close to the big disk’s circumference.
    Put a spindle (screw) through the hole in the middle and connect to a handle (bit of wood).
    Then, spin the disk with fingers.
    No arduino, led, battery, ping pong balls required.
  11. fartface says:
    Note: that cool thing will set off bomb detectors. Ping Pong balls have a lot of nitrates in them and bomb sniffers will ID you as having handled bomb making materials.
  12. HackJack says:
    Thank god for the arduino, making a project like this possible for the ‘everyday man’
    • n0lkk says:
      But this was done long before the arduino, the integrated circuit, even before solid state devices. Even maybe before vacuum tubes, but I not sure of that though a light chasing circuit would give the same effect. AFAIK there is now law saying a straight line of them can be pulled into a circle. Not dissing the arduino, those using them make great things with but it’s creating a group of electronics hobbyists that aren’t learning what came before. I’m of the opinion those who do will be able to do more with the microcontrollers.
  13. DerpDerDerp says:
    The ‘loading animation’ is more accurately termed a ‘throbber’.
    http://en.wikipedia.org/wiki/Throbber
    PS. I have a large throbber.
  14. omo says:
    i don’t see why certain people complain about the arduino being used. even if the project could be engineered better and more economical, that’s not the purpose. i doubt the project will be mass produced. the arduino is a fast way to set something up, film it and put it online. after that is done, the arduino could be used for something else.
    • Mark says:
      Exactly. If you want to show off your mad EE skillz, go ahead. Otherwise, you can use the time you saved to build something else cool and re-use the Arduino for that.
  15. steve eh says:
    am i the only one who sat and stared at that front page animation waiting for the fucking good part to load….lol jk
    cool idea i like it
  16. atomsoft says:
    Awesome! i do agree that its a waste to use the whole Arduino board but you can simply program the main ic and remove it from arduino and use that IC alone … that would save money. Using too many ICs like a 4017 mixed with a 555 or what every just over complicates things. Thats why they invented MCUs i assume? I say a MCU alone is perfect just dont use a whole dev board … πŸ™‚
  17. I have 40 Gigabits up and down. I’ve never seen the spinning octet before.
  18. Drew says:
    I love it, it’s something I’ve been thinking about building for quite some time. I aggree with the Offline requests, even better would be to opensource it, do as WordPress does and offer a hosted version (maybe for a fee) and a download of the software.
  19. Wilcorp70 says:
    All the negative comments about how this is over powered because of the arduino made me think. Maybe there should be a submission system for posts like this where people could submit simpler/cheaper circuit diagrams that could be added to the post. That way we would have an intro into how to prototype this with a uC and also how to move to a more finished cheaper version. Everyone wins.
  20. Kshatrya says:
    AM I the only one who noticed that he used Vimeo to post about YouTube?? -G-
  21. Eirinn says:
    Lol people saying the arduino is overkill for this project must have their heads so deep down in assembly that they don’t really not everyone is an EE.
    Sure the Arduino is expensive for this, but is still astronomically cheaper than paying for EE classes and doing this:
    “An arduino to shift 8 bits ? Come on !
    A single 8 bits shift register, a couple of logic gates (or an OP amp) as a improvised clock, and some capacitors for the dimming effect and there you go!”.
    I’m not saying it’s wrong! I’m saying that it’s unlikely unless you have the expertise πŸ™‚
    Brb going to make a moon rocket out of gaffers tape and a lollipop stick.
    • Eirinn says:
      Aparently i have my head so deep in my ass that i didn’t re-read the comment “that they don’t really not everyone is an EE.” should of course be “that they don’t realise that not everyone is an EE.”
  22. But can you play the snake game on it like you can with the real one? :V
  23. Richard says:
    An Arduino is an extremely efficient way to do this, if you make the assumption (I suspect quite reasonable) that this particular thing is a novelty item, and the Arduino will be repurposed for some other function later on. Perhaps this isn’t the first use of that Arduino, either.
    A custom solution using shift registers and such might have a lower gate count, and might be cheaper in mass production, but the specialty hardware wouldn’t be of so much use for the next hacking project. General purpose hardware that’s reusable wins when reused for many one-off projects with a short useful lifespan. If the development costs are counted, it might even win when used for a single prototype project.
    How many of you are reading this post on a computer that has the minimum hardware required for the task? Even a beagleboard would be overqualified, but I bet most of you are using bloated general purpose computers with things like sound cards, gigabytes of excess memory, and disk drives that dwarf the Arduino’s excesses. Versatile general-purpose mass-produced hardware is very reasonable when you use it for multiple tasks.
  24. War_Spigot says:
    Now, someone make one with a whole array of LED’s so you can play snake on it.
  25. PJ Allen says:
    Look, Ma – No Arduino!
    http://www.youtube.com/watch?v=qp-7i9uWu64
    You can, too!
  26. Retroplayer says:
    As an EE, I think the arguments about doing this in discretes is just posturing. Yep, I can also design such a simple circuit using discretes. But you know what? I wouldn’t have. I would have used a microcontroller, because it would be faster, simpler, cheaper, and provide for adjustments through software.
    Granted I would not have used an arduino, either. I won’t say it is overkill, but if it gets people building stuff that otherwise couldn’t, then awesome.
    My point is that doing it with discretes is not simpler or really cheaper at all. It does show off a bit more, but so? Maybe there is a bit of rage in the fact that because of the arduino, people can now do the things that use to make you look really smarter than other people, and more special? For being smart people, there sure are a lot of sensitive egos in this industry. I deal with it every single day. Grow up and stop being so angry at the world.
    I certainly would have built a lot of things differently if I were to build this (like using pingpong balls on the T-Shirt is clunky and kind of tacky to me) but kudos to the dude for doing it, anyway. It’s not MY project; it’s his.
    • Cyril says:
      Ego?!?!?! P-lease…
      Here’s a hint: Notice the bazillion non-arduino “microcontroller as a switch” or “microcontroller as a super-simple LED driver” so called featured articles? No? Why is that? Does it have anything to do with “monetisation”?
      As for learning, what of value was learned from copying someone else’s design, someone else’s code and the endless sycophantic koolaid guzzling ra-ra?
      If the naysayers are so ego motivated, what of the motivation of the “faithful” that demand gold medals and sycophantic praise for mere participation
      To parallel microcontrollers to TV shows, the ‘duinos (et al) are the “Jersey Shore”, where their only virtues (from an electronics perspective not art) are laziness, vanity, shallowness, self-importance and an absolute sense of entitlement.
      Mediocrity seems to be the new awesome… which is well, like, totally, super-awesome! *self flexed-bicep kiss*
  27. Hacksaw says:
    I don’t care how he did it…I now have my Haloween costume planned…
  28. Peanuts says:
    Is anyone else not able to see the code he is using? I get 4 lines and nothing more… I’m still learning and would have enjoyed playing with the sketch.
  29. racing says:
    I saw the Ongais Interscope 935 in Vasek Polak’s collection some years back. There was a Porsche F1 car there as well.
Leave a Reply to Bakamoichigei Cancel reply
Related Hacks in led hacks
