Tesla gun will probably kill something, sometime
After reading The Five Fists of Science, a retelling of ‘war of the currents’ between [Tesla] and [Edison], [Rob] knew he needed a Tesla gun, the sidearm of the story’s protagonist. Since nothing as stupidly awesome and dangerous as a portable Tesla coil has ever been made, [Rob] needed to make his own.
[Rob] started his build as any good weird weapon build begins: taking apart a Nerf gun. A new Aluminum sand cast body replaced the wimpy plastic body of the Nerf gun and after a few days on a mill, [Rob] had an aluminum Nerf gun perfect for holding the guts of a Tesla coil. The high voltage switch is made of porcelain, and the power supply is an 18 V cordless drill battery and a flyback transformer potted with silicone in a PVC pipe end cap.
[Rob] really has a remarkable build on his hands here, and certainly something no one else has ever tried before. While he hasn’t fired his gun yet, we’re sure we’ll hear about it on the nightly news when he does.
  1. No One says:
    Correct me if I’m wrong but he just needs to wear a Faraday cage to protect himself, right?
    • carbinefreak says:
      Yes, but the current generated by this is so small that it should be mostly harmless…..mostly….. mmmm burning hair
      • marshkillz says:
        agreed, the only real dangers would be joule heating and possibly undischarged capacitors (of which it looks like that’s covered by bleeder resistors).
      • Actually, I saw Rob explain this thing at Jigsaw Rennaissance a few months back. He said it threw about 10x the amperage of a taser. It made ~6″ sparks, and hands went over ears throughout the room when he fired it. So, no, not harmless at all.
  2. Paul says:
    Ring-mail or plate armor would work as well as long as he is completely covered like the suit worn by Arc Attack.
    http://www.youtube.com/watch?v=PdrqdW4Miao
  3. Paul says:
    I didn’t read the article yet but it seems to me that the “gun” will fire in all directions. There needs to be a method of forcing everything forward instead of all directions. And along that thought, electricity is going to want to find it’s own path so he’s going to need a lot of energy to make it go the way he wants.
    • fightcube says:
      What if you could ionize the air in front of the tesla gun using a mini air vortex cannon, just prior to firing the tesla coil?
      This is kind of how lightening strikes work, minus the forced vortex. You provide a conductive path through the air…
      • Paul says:
        Since electricity follows the path of least resistance using a squirt gun to guide the charge would probably work.
      • guieut says:
        Could it be one with a laser?
      • marshkillz says:
        @guieut You possibly could use lasers, although the equipment necessary would likely make a portable one impractical. http://www.sciencedaily.com/releases/2012/03/120313092058.htm
      • fightcube says:
        @Paul, good idea! I guess if you are getting hit with 1 million volts you mights as well be wet as well. If you could get enough current to flow through it the water would vaporize and put on quite a show.
      • Excellent idea! – Although Tesla had this worked out in 1940. He used compressed air to generate the very High Kv and then (coincidentally) accelerated tungsten particles (through a vacuum gap called a lens) in a stream like a BB machine gun at the carnival. Tada! That’s a patent you’ll never see, though.
        Nowadays one uses pulsed lasers to ionize out a nice path for the HV to follow. If you like tasers, you’ll love these bad boys.
        An interesting side effect is the complementary coronal discharge bruise/burn tattoo the target receives with every trigger squeeze. It’s also the only thing keeping it off the market, but once that gets solved (and the likelihood of instant cataract/optic nerve damage) we should see them available for a variety of enforcement purposes.
        May the odds be ever in your favor. 🙂
  4. Chris says:
    A Faraday cage protects from the secondary arcs. Because they’re high frequency, they don’t penetrate skin far; so no risk of it stopping your heart or affecting other internal organs. And they’re very low current, so they don’t do much damage. Even a direct strike to skin only leaves a surface burn, which will turn into a welt later. If you can control where it hits you, it’s protection enough to cover just that part with metal to spread out the initial point of contact. Cover your fingertips with aluminum foil and you can draw arcs to them all day long.
    The real danger is if a secondary arc strikes the primary and you at the same time, which connects you directly to the 20kV capacitor bank. Nothing low current or high frequency about that. Don’t count on a second chance if that happens. And any flaw in your Faraday cage may mean it fails to protect.
    I have seen other handheld Tesla coils. Not many, though. They are used with a professionally made Faraday suit. Or they operate at low power, with extra physical separation and insulation between primary/secondary to (hopefully) eliminate the possibility of a primary strike.
  5. Scuffles says:
    “Tesla gun will probably kill something, sometime”
    My money is on the operator 😛
  6. muffin says:
    I disagree with the sensationalism of your post for two reasons.
    Hack-a-day recently posted about /several/ portable tesla coils, including HatCoil: http://www.theinspiration.com/2012/05/live-classical-music-in-the-copenhagen-metro/ and the DIY plasma gun: http://hackaday.com/2007/08/08/diy-plasma-gun/
    Additionally, Tesla Coils aren’t inherently dangerous. I remember my teacher shocking willing students in class with a hand-held tesla coil (that the school bought). Though I admit that I couldn’t tell whether or not a Tesla Coil is dangerous (The load of a human would probably alter the output voltage of a tesla coil), there’s no reason to call any Tesla Coil dangerous.
    I’m also uncertain why hack-a-day seems to be infatuated with safety, usually where it isn’t even a concern.
    Nevertheless, [Rob] is freaking awesome – as is his new Tesla Gun! I’m glad you guys decided to feature him 🙂
    • Paul says:
      I think they’re concerned with safety because they don’t want to get in trouble when Bob over there in the corner decides that this is a cool project and stops his heart when fiddling with the high voltage parts of the project. Let’s face it, Bob isn’t too bright some times and maybe he followed the “instructions” or maybe he didn’t. Maybe he built it bigger. When he’s dead all that anyone will know is that HAD said, “here look a this. Isn’t it cool! You can build your own.” If they tell everyone it’s dangerous then at least Bob will know he might not want to try it on his own. And then HAD can say, “look, we told him it wasn’t safe.
      my $0.02 anyway.
      • Chris says:
        They suddenly became “concerned” with safety ever since they posted regarding the negativity of commenters, and demanded a change.
        I think they’re now trying to point out any safety issues themselves, so that others are less inclined to do so.
    • It’s extremely weird concerning safety and commentors on HaD.
      If I put up a post about a hand held tesla coil, people complain I’m too focused on safety.
      If I put up a post where someone uses PVC pipe as a potato cannon, people start chewing me out saying PVC should never be used as a pressure vessel, this post is stupid and dangerous and it’s going to kill somebody and probably maim several children and cute animals.
      You can see there’s no way for me to win here.
      • Chris says:
        LOL, yep. Just look at it as a license to write whatever you want, since no matter what, someone will disagree. 🙂
        Besides, some of the post titles, while perhaps sensational, have brought me a chuckle.
      • muffin says:
        We’ve had similar problems over at instructables. Namely, ‘safety trolls’ (who wouldn’t even contribute to the community) thought it was a good idea to find every instructable that could be potentially dangerous and chew the author out for not mentioning safety. The way I’bles handled it was to ignore/remove the comments if they were unreasonable, and they added a clause in their legal terms of agreement about risk and liability.
        Eventually, the problem sort of went away. ::Shrug::.
  7. Bill says:
    “Since nothing as stupidly awesome and dangerous as a portable Tesla coil has ever been made,”
    “and certainly something no one else has ever tried before.”
    Not only has this been done before, it’s been covered by HAD before….
    This one is bigger, but still the same basic design and power source.
    • jb0x168 says:
      It’s also been fired, at least in a preliminary fashion. He gave a demonstration of it during the Jigsaw Renaissance Open House for their new makerspace.
  8. Hirudinea says:
    “No Mr. Bond, I expect you to die.”
  9. LOL says:
    WOW! Tesla Trooper!
  10. n0lkk says:
    Well the gun had to been fired to create this http://www.flickr.com/photos/hackerfriendly/7005406212/ and other photos Perhaps it’s a photo-op only prop, but it’s funny to see an old typewriter on a shop bench rather than the expected laptop computer. In the event I was a school shop or science instructor that’s the lab coat style I’d want.
  11. Chris J says:
    Yeah. Where did he get that coat?!
  12. andar_b says:
    Come on… I’m the first to mention he needs to make it a LOT smaller to sell these to the Warehouse? Can you imagine Pete and Myka carrying these around?
  13. Pilotgeek says:
  14. ferdinand says:
    it look it is make by doctor who to kill some darleks
  15. Slegiar says:
    please tell me i’m not the only one who looked at the title and immediately thought “warehouse 13”
  16. Leithoa says:
    @ fightcube
    the vortex is a bad carrier for ions since the rings themselves are fairly stable and don’t lose that much of the gasses that make them up. I beleive the groups that get DARPA funding for solving this type of problem use UV lasers to ionize the air before the weapon is triggered. But as was said before, the equipment needed to get the concept to work as advertized isn’t man-portable yet.
    @ Chris J
    it’s a custom coat someone made for him according to his blog. I’ve seen similar styled coats worn by professional chefs so you could probably find a pattern or buy one at a restaraunt supply store.
    • fightcube says:
      Cool.. good to know 😉 Hadn’t thought much past how lightening works…. I’ll have to tuck uv lasers into my knowledge pocket. thanks.
  17. Jennifer Elaan says:
    My wife’s been making these for years now, and has much better arcs. And music:
    http://www.youtube.com/watch?v=9W3YpO0wwEg
  18. Leithoa says:
    @Jennifer
    Is all that white noise there in real life or is that just RFI playing merry-hob with your camera?
    • Jennifer Elaan says:
      That’s not white noise – that’s the rotary converter that she decided to use to get the +400V for the input. Her previous designs used a solid state converter, but there’s a certain charm to a screaming dynamo.
  19. Johan G says:
    I might dream nightmares about someone in a dark alley playing petrifying horror movie music while electrifying his victims. :-S
  20. Plutohydra says:
    Youtube video of the actual gun
    http://www.youtube.com/watch?v=h5jBjso6l6I
  21. BobLoblaw says:
    Actually things like this have been done before. It’s on youtube.
Leave a Reply to Jennifer Elaan Cancel reply
  • electronic table top catapult
  • Sentry gun controller-board upgrade
  • Birdwatching Meets a Computer-Controlled Water Cannon, Awesomeness Ensues
  • A Full Auto PVC Battery Gun
