A bit about the diode
Most of you already know what a diode is, but how much do you really know about the device?
The diode is a component which allows current to pass in only one direction. Originally they were made by placing a positively charged anode plate within view of a tungsten cathode in a high vacuum. By heating the cathode to several hundred degrees, the metal’s work function is reduced enough that electrons with may leave into the vacuum using only a few volts. These electrons would then be attracted to the cold, positive anode and would flow into it and out of the tube. As the cold plate’s work function was several magnitudes higher than the cathode’s, there was a greater probability that current would flow in only one direction.
While this thermionic process works very well and very fast, the heater requirement ends up making the diode quite inefficient. As a result thermionic diodes are only used when frequencies of several hundred megahertz must be rectified at very high powers; they’ve largely been antiquated by the semiconductor diode in most applications.
Semiconductors are neat little elements. When pure, they are very good insulators and will not conduct. It’s possible though, to coax these materials to either conduct electrons or holes, simply by adding some impurities to the crystal lattice. By throwing a few atoms with more than 5 valence electrons into the lattice the semiconductor will be able to conduct electrons, creating an N-Type semiconductor. Likewise, by throwing in a few electron-few atoms it’s possible to conduct holes, creating a P-Type material. By sandwiching these two types together we can form a PN junction; a diode.
With the P-Semiconductor biased positively and the N biased negatively, electrons easily can flow into the diode, jump across the small 0.7V depletion region and leave to continue on their merry way. If the diode is biased incorrectly though, holes and electrons migrate away from the junction and a very big depletion region is formed. In fact, the junction turns into a few-picofarad capacitor, and in some cases may even be used as such.
As great as they may be, PN junctions are lossy little things. Though they do a really good job of blocking reverse current their 0.7 (now, 0.5) volt depletion region will readily burn 14 watts if 20 amps are to be rectified. Not only that, but it takes significant time for the diode to ‘recover’ after a reverse-bias, thereby limiting the speed at which it may rectify. 1N series diodes are usually no good for anything more than 400Hz! UF series diodes are much faster and may operate at 100kHz smoothly, but anything more than 500kHz is a bit much to ask for. I suppose we can’t complain though, since they sure beat the hell out of coherers!
I hope you all liked this article; in the future we’ll take a look at specialty diodes!
  1. qiron says:
    Thank you !
  2. Sheldon says:
    The 0.7v/0.5v thing is not a property of age (reading into the use of the phrase “now 0.5” in the article) but a material property. Silicon diodes are typically 0.7v but germanium based ones are typically 0.5v (they both can be different values but generally characterised with these values).
    There are also diodes that are formed in the same way as the “cat’s-whisker detector” in old radios, i.e. it’s a metal-silicon interface to create the barrier, rather than being between P and N-type doped material (this is more commonly known as a Schottky diode and has a lower junction voltage compared to silicon n-p junction).
    • asdf says:
      That last bit might be misinterpreted.
      Just to clarify…
      He is saying that the Schottky is a metal to silicone interface, not a P to N-type interface.
      Sorry. The sentence structure bugged me. 🙂
  3. Sly0 says:
    so where would you use diode that big as in the picture? )
  4. hboy007 says:
    diode voltage drop is still variable (see Shockley diode equation), power devices can have drops from 0.4 to 2V depending on the current.
  5. Alan Yates says:
    The forward voltage drop is a function of current and temperature, look up the diode equation for the gory details. This is both annoying and useful.
  6. Sven says:
    Why did they use a picture of a huge SCR (not not strictly a diode) and not, say, an 1N4148 or 1N400x ?
  7. Craig says:
    Nice article, thanks for taking the time.
  8. Destate9 says:
    What!? You had to have a power source for a diode equivalent back in the day!? That’s nuts, thanks for the interesting article!
  9. gnomad says:
    One of my favorite LED tricks is to connect both pins through a current limiting resistor to two MCU GPIO pins. The LED can then be reverse biased to charge it as a capacitor. Then flip the cathode to input, and count the number of cycles for the pin to transition to logic zero state. The “capacitor” will discharge as a function of photons hitting the junction, thus turning it into a light sensor. When wired this way, the same LED can be used to both produce and measure light!
    • Slanderer says:
      You *can* do that, but LEDs make atrocious photodiodes. Real men with hair on their chest use PIN photodiodes, transimpedance amplifiers, and capacitor values chosen for ultimate bandwidth.
  10. stormdog says:
    Huh. I was more intrigued by the link to coherers. I’m amazed how I still come across interesting components I’ve never heard of.
  11. Null says:
    You should have mentioned mercury arc rectifiers 🙂 way more impressive lol
    http://en.wikipedia.org/wiki/Mercury-arc_valve
  12. NewCommentor1283 says:
    maybe im wrong, maybe im very wrong, but either way,
    im going to say this:
    a small signal diode (1N type), if run at ~1/2 current will have a voltage of about 0.666 …
  13. Njay says:
    Here’s some real world silicon well-known diode V-I curves I measured:
    http://img507.imageshack.us/img507/408/curvasdedodoscomuns.jpg
    1N5817 is a Schottky diode; these have lower forward voltage drop and are really fast (and have higher reverse current leakage).
  14. Njay says:
    Here’s real-world diode curves of some well-known types I measured (text is not English but the juice is in the pic):
    0.6V… 0.7V… what’s the diode’s voltage drop after all?
    1N5817 is a Schottky diode; these are super-fast, have lower forward voltage drop (Vfw) and higher reverse current leakage.
Related Hacks in Ask Hackaday
  • A bit about the diode
  • Ask Hackaday: Building nano scale antennas
  • Ask Hackaday: Did you catch the Grammys?
