Foot-controlled mouse keeps your hands on the keyboard
A bit of mechanical ingenuity makes building this foot-controlled mouse into a fun project. It consists of a platform which hosts one pedal for each foot. The right foot controls the movement of the cursor, and the left is responsible for the buttons.
The guts of a wireless mouse do most of the electrical work for this hack. You can see that the optical sensor is mounted on the front of the right foot pedal. A ball bearing combined with a hinge provides motion on two axes. This moves the sensor past a piece of curved foam made by covering a ball with plastic wrap then spraying foam insulation around it. The pedal on the left has four buttons actuated by moving the toes down, up, left, or right. There’s a centering mechanism for this pedal which uses a rubber band
One thing we wonder about here is whether there is a need to lift and re-center the mouse/cursor? There is also no scroll wheel. But those issues are just waiting for someone to pick up the project and make their own improvements.
  1. Dax says:
    Mouse sensors are nifty. If you come across a wireless mouse that uses one of the ADNS cameras, it’s very easy to interface to a microcontroller using the reference design in the datasheets. Just pull the camera and lens out, and do whatever with it.
  2. rue_mohr says:
    yay! its not exactly the same as my foot controlled mouse! oh wait, I think its better, damn…
  3. Lord John Whorfin says:
    “Feet! Do your stuff!”
  4. st2000 says:
    Simple, obvious, functional – excellent project.
    I think most cameras are independent of the controller chip inside the mouse. So you could probably simulate picking up the mouse by opening up certain lines between the camera and controller chip.
    That, or you might try to experiment turning off the LED to see if the camera will be “silent” when in the dark.
    As the mouse is normally used as a relative positioning device – this “more absolute” positioning device may be problematic. So, could something the size and mass of a boccie (spelling) ball used as a foot track ball be better?
  5. Decius says:
    It’s a Foot Alcher!!!!
    Just kidding, you shouldn’t be alching anyways…
  6. joseph says:
    yes…on the keyboard….
  7. nah! says:
    this is way overthought, a 2 axis potensiometer aka joxstick would be much more appropriate.
    the old ball mouses had them wheels which would also work.
    • DossierD says:
      Well, I have thought about almost every possible solution. And that is not enough for a good accuracy. The position of my right pedal sets directly the position of my mouse.
      My best idea was to attach a door hinge on a ballbearing. So the mechanical construction is the main thing.
  8. gizmoguyar says:
    People are discussing the need to pick up and re-center a mouse, however there are a number of readily available plugins that allow a game controller (such as an airplane joystick) to be used as a mouse. This would allow for absolute positioning on the screen as opposed to relative.
  9. wetomelo says:
    Good hack for disabled people +1 !
  10. This is cool, I never thought of it… but wouldn’t it also be cool to just look at the think you want to click… you are already looking there anyway.
    • DossierD says:
      You mean some kind of eye-tracking-mouse ?
      They are getting more accurate over the years. They are also expensive. But it’s a good solution for people who can’t use their hands and legs.
  11. WhatNow says:
    There are keyboards with mousewheels. I have this Logitech kb and there’s a mousewheel with a back button on the left, next to the capslock.
    PROBLEM SOLVED.
  12. PKM says:
    For “picking up” the mouse, I guess you want a button which will either disable the sensor somehow (turn off the LED?) or perhaps move the foam surface away out of range of the optical sensor.
    If your OS does that mouse precision thing whereby faster movements move the cursor more than slower motions, you don’t actually ever need to pick up the mouse- just move quickly in the direction you want to go, and slowly back, and the cursor “ratchets” in that direction.
    • DossierD says:
      There is no need to pick up the mouse. If I move my cursor to the side of the screen, my footmouse can move further. When I return the pedal of my footmouse, the cursor starts moving immediately.
      So by swinging the pedal of my footmouse to the sides, the cursor is back in the middle somewhere. I do it without thinking.
      Do you know how you center the cursor with your normal mouse ? Some people pick it up and place it back on the table, others make a swing to the sides, or a combinations of both. It’s easy to do, so normal mice don’t have a “put-the-cursor-in-the-middle-of-the-screen-button”.
  13. Jonathan B. says:
    I really think the niche here would be for disabled individuals who can no longer use a regular mouse.
  14. DrSarkastik says:
    Great. It took so long to educate people that the CD tray is not a coffee holder and that the mouse is not a foot pedal, and now you build this.
Leave a Reply to Brett W. (FightCube.com) Cancel reply
