Cockroft-Walton Multiplier can output positive or negative voltage
If you’ve already dipped your toes into high-voltage power supply pool you may be thirsty for a bit more knowledge. Here’s a neat illustration of how to build a voltage multiplier that can output a positive or negative supply. It is based on a design known as the Cockroft-Walton Multiplier. It’s the add-on housed in the plastic box seen in the image above. It uses diodes and capacitors in an orientation very common for generating high voltages. In fact, the same thing can be found in that high-voltage bulletin board. The place this differs is when it comes to connecting the multiplier to the PSU.
If you look closely you can see one red and one black banana plug jack poking out the end of the plastic container. There is also a pair of these on the other end. The multiplier has been designed so that reconfiguring the inputs and outputs changes how it works. Each jack has been labeled with one possible input and one output. Choose the desired output (DC+ or DC-) and then follow the labels for the rest of the connections.
What can you do with this setup? Check out the clip after the break that shows it powering a lifter.
[youtube=http://www.youtube.com/watch?v=p10OUADRr2M&w=470]
  1. Natalie says:
    Like to see a photo of it in the dark to see how well the design suppresses corona at the connectors.
  2. War_Spigot says:
    Correction, if you’ve already dipped your toes into high-voltage power supply pool you may be paralyzed from the neck down.
  3. Physics_Dude says:
    ZAP ALL THE THINGS!
  4. Mark says:
    Very unfortunate choice of metaphors. 🙂
  5. Pinky says:
    How is this ever supposed to reach 250 kV? Those cables and plugs certainly don’t seem up to the task and the air gap is far too small, with some safety margin you need around a meter.
    • Munch says:
      You can have 1MV on a #28 piece of wire if you wanted. The question is how much current is flowing at those voltages. If the current is low enough (which implies you’ve taken precautions against arcing), you can use a hair-sized piece of wire to convey whatever voltage you want.
      • Pinky says:
        When I talk about the plugs and wire I mean their insulation is pretty much irrelevant to arcing at 250 kV (it could go straight through the insulation if need be, although it will just escape via the plugs).
        So it all comes down to distance, the usual precaution against arcing for 250 kV in air is a gap of >50 cm … this box doesn’t look large enough to hold off 250 kV from one side to the other.
  6. Munch says:
    A child, bare feet, and high voltage. What could possibly go wrong?
  7. Black Soap says:
    Hooray warning labels!
  8. Bob says:
    I have not tried a C/W multiplier, but I have built various designs and sizes of the lifter shown in the video. I happened to score a 75KVDC transformer several years ago via ebay, and run it through a variac to control power. Spearating anode from aluminum foil helps create better ion flow and prevent spark over. The biggest unit I made was a triangle with 6 feet sides. It is still incredible to watch in my opinion…
Leave a Reply to Pinky Cancel reply
Related Hacks in misc hacks
