Doing it right with a morse code keyboard
Hackaday has seen dozens of Morse code keyboards over the years, but [Hudson] at NYC Resistor finally managed to give that idea the justice it deserves. He built a USB Morse code keyboard with the same type of telegraph key the pros use.
For his project, [Hudson] got his hands on a wonderful iambic paddle that is usually hooked up to CW rigs. Unlike previous Morse keyboards we’ve seen, [Hudson] used iambic paddles, a telegraph key with one lever for dits and another for dahs. Because the dits and dahs are separate electrical connections, it’s extremely easy for the microcontroller – a Teensy – to parse the Morse code and send the correct letter to the computer.
[Hudson] also added some audio feedback for the dits and dahs, and designed a laser-cut enclosure for the Teensy and speaker. Check out the video of the iambic keyer keyboard in action after the break.
[flickr video=6889388305]
  1. Th3badwolf says:
    Kudos!
    Very nice build!
    Considering it myself now =P
  2. sqkybeaver says:
    this would make it hard to play FPS!
  3. D says:
    This would be nice for the blind, maybe.
  4. RandyKC says:
    That’s the way it should be done.
  5. Gary says:
    Have been searching all night and can’t find where to buy a Teensy in the UK. Where can I get a couple of these? Thanks
  6. ptor says:
    Gary,
    Could you order one internationally from the US? Say from adafruit.com?
Leave a Reply to RandyKC Cancel reply
