Rapid fire update brings many new features
[Shawn McCombs] has been spending some time refining his Xbox 360 rapid fire hack. This time around he’s got a lot more features, many of which we haven’t really seen before.
When we looked at the original project he had added an ATtiny85 which read a potentiometer to set the rapid fire speed for one of the buttons. This time around he’s opened up settings for individual weapons in the game. For instance, if you have a hand-gun and a rifle, you can set different rapid fire rates for each to account for the reload speed for those guns. He patched into the ring of LEDs on the controller in order to indicate which preset is currently chosen. There are three tactile switches on the underside of the controller too. One of them is a reset button which gets you back to your primary weapon and the default rapid fire rate. Settings for each weapon are saved to the EEPROM so you won’t lose them when the controller goes to sleep. Check out [Shawn’s] description of the project in the video after the break.
[youtube=http://www.youtube.com/watch?v=68Kbnq3sa8I&w=470]
  1. Gdogg says:
    I’m not sure I would put the work of someone who can’t spell “Thief” into my $60 controller. Like I said last time, there are better ones around.
    He’s keeping the reset pin floating and using seemingly random resistor values, as well. Not the worst I’ve seen, but pretty dirty.
  2. ben says:
    you dirty cheater i bet you use it on cod shame on you
  3. Mizchief says:
    As a hacker, I say great job, that is a nice hack.
    As a gamer, I say keep your cheater controller out of xbox live!
  4. anonymous says:
    If you watch the video with the sound muted and ignore the video, it reads like a personal ad.
    So v e r y strange. 😛
  5. NewCommentor1283 says:
    @Mizchief im lost, this is cheating how? in the game i frequent this would only help you aline your presses with each wepon’s semi-auto action, but not make it shoot faster?
    PS: im a keyboard man, so explain to me…
    i dont see anything wrong with his schematic. aside from floating reset, i would think the controller’s housing would do a fair job of shielding static at least, i think EDIT i read there is a pull-up resistor INSIDE an Atmega162 mcu! FIGURE 21 in PDF datasheet
  6. marxgen says:
    LOOPS *gasp* loops
    my Arduino is rusty so there is probably errors in this but I feel so much better after having written it.
    if(mode == 8) {
    //analogWrite(rtrigPinout, 255);
    digitalWrite(rtrigPinout, HIGH);
    ltrigValue = analogRead(ltrigPin);
    // if ltrigValue is more than half
    if (ltrigValue >2; //knobDiv = knobValue/4
    digitalWrite(ltrigPinout, HIGH);
    unsinged int i = 0x0;
    delay(40);
    for(i=0;i<=knobValue;i=i+knobDiv){//0,1/4,1/2,3/4,1 == 5 times
    delay(knobValue);
    //should define a threshold rather than chose < 1
    //in the case there is some noise on the trigger line
    //#define THRESH 10
    if(analogRead(ltrigPin)){
    break;
    digitalWrite(ltrigPinout,LOW);
    • marxgen says:
      WordPress nuked my indentation sry
      http://pastebin.com/aparwpgd
    • kuni says:
      The amount of redundancy in the source code makes my head hurt. I wholeheartedly agree with throwing some loops in there.
      • Alex says:
        Shawn McCombs may think he knows C, C++, Python, HTML, CSS, and Ruby, but with that kind of code, I would reason to say he isn’t good in ANY language. Yes, the code works, but it’s wayyyyy too long for what it actually accomplishes. Also it’s one huge huge loop, that I imagine may run a little slow (or as too frequently I have experienced in Arduino, very very slow). The project itself definitely has potential though.
  7. Shawn McCombs says:
    Well Gdogg, My name is as it is because I want it to be. It also seems your getting mad and I wounder if maybe because I’m giving away a design that will ruin your PIC rapid fire kits you sell on ebay? lol
    anonymous, I thought adding personal comments about my self would establish more of a connection between me and the viewer. I also found it very artistic once I got started.
    And as for the reset. You can connect it if you want, but mine works fine as it is.
  8. advocatus says:
    most commenters here remind me of the fat ‘Comic Book Guy’ from The Simpsons… always bitching and hating.
    nice work dude. thanks for sharing and keep hackin
  9. Shawn says:
    Well GDogg, it seems my mod makes you mad. My conclusion is that your one of those people selling PIC rapid fire kits on ebay.. lol
    anonymous, I thought that adding personal comments would connect me more to the view, I also found it somewhat artistic.
    marxgen Thanks for the help, I hope this picks up and more people add to it.
  10. UltraApple says:
    I like it. You set a goal and made it work. There have been some great suggestions to improve it. Good job on prototype 1. I’m sure your next rev will include a lot of the suggestions. Keep on Hacking. Have fun playing “Single” player games! 😀
    Cheers
  11. DS says:
    Thing is it makes you look like a cheater since you’re shots are identically spaced apart.
    Why not throw in a random number generator to generate a random delay between each shot but still be fast.
    That way your victims will think they got owned by a legit player with a fast finger rather than a mediocre player with a controller mod.
  12. Shawn McComb says:
    Well honestly if your a good player. You can pull the trigger as fast as the gun will allow you to.
    Another note, on games like bf3 the users screen shows you firing super fast, but on other peoples it shows you firing really slow at different rates. I think the game still registers your shots though.
    And on most games you usually can’t even count how many shots hit you before you die anyways. So how will they know? The only way is kill cam, so you would be playing COD which is a online game, plus AIs wouldn’t care if you shot them twice at the same delay.
  13. Madness says:
    Nice hack, but…
    Stay off Xbox Live. They will find you. And they will ban you. And maybe your console too. Not to mention, this gives you an unfair advantage… Which is why they will ban you. Play fair.
Leave a Reply to advocatus Cancel reply
Related Hacks in xbox hacks
  • Computer control for your Xbox controller
  • Rapid fire update brings many new features
  • Reclaim the wireless controller module from a broken Xbox 360
