Hexbug code rewrite makes it a walking line-follower
You know you’ve got a good hardware platform if you can easily repurpose it with a code rewrite. And that’s what [Eric] continues to do with these little Hexbugs. This time around he’s bent the IR emitter and receiver downward to use as a reflectance sensor. This gives it the ability to follow a dark line on a light surface.
He originally patched an MSP430 into the $25 RC toy. The IR pair was intended for obstacle avoidance, which we saw in a recent links post. This hack does a great job of repurposing the avoidance system. Since the add-on hardware is mounted on a motorized turret, the single sensor pair can sweep back and forth to find the line it will follow. In one way this is better than most line followers which use multiple sensors mounted to the body. But the drawback is that this results in slower travel and won’t be winning any contests. Don’t miss the demo clip after the break.
[youtube=http://www.youtube.com/watch?v=sA1hMtLhBdQ&w=470]
  1. jim says:
    it’s adorable!
  2. johntash says:
    I still want one of these. So much cheaper than building a big hexabot or buying a kit x_x
Leave a Reply to jim Cancel reply
Related Hacks in toy hacks
  • Digital Magic 8 Ball
