Robotic Etch-a-Sketch Draws Grayscale Images
[Patrick] decided to make a computer controlled etch-a-sketch. While the idea is not that new, there is always a different way to accomplish a goal. An Arduino is used to control a pair of stepper motors which were sourced for pretty cheap, and even came with their own driver. Next a stand was mocked up using foam board, which helps determine where all the parts should live.
Next was a way to attach the steppers to the knobs, gears would be used and a collet meant for model airplanes was sourced to make the mechanical connection between gear and shaft. With everything set in place via foam board and paper printouts, it is off to get some thin plywood. The plywood is sent though a laser cutter creating most of the stand and gears. Now its all software, a program was whipped up for OSX which converts low res pictures into squiggly lines perfect for the etch-a-sketch to draw on its screen.
The results are quite impressive, join us after the break for a quick video.
[youtube=http://www.youtube.com/watch?v=q2LIMYKQLXE&w=470]
  1. ejonesss says:
    hmmmm? couldnt this be used to smuggle data?
    you program something you want to smuggle say a phone number or a password or something then you take the unit to where you are to reveal the message and bingo you got a method of smuggling a message
    then you can have an erase button on the logic board to erase the memory and then you shake the etch a sketch to erase the message like usual.
  2. Max says:
    And it’s so fast !!!!
  3. andyh says:
    Lovin this, though i cant help thinking weve just reinvented the HP single pen plotter from the 1980s. Time to start digging out those vector drawings of the space shuttle and we can go on a complete nostalgia trip. (BTW it should be plotting high res vector art, .svg files and hpgl plot files, never mind all the low res pixel nonsense).
  4. mike says:
    an etch-a-sketch ‘digital’ picture frame would be incredible.
  5. MrX says:
    Not to be a troll but his automated drawings look like crap. If you attempt to automate an etch-a-sketch, at least build it to make *better* drawings than artists:
    http://www.odditycentral.com/pics/incredible-etch-a-sketch-artworks-by-george-vlosich.html
  6. Hirudinea says:
    Next make it print out a Twitter feed.
  7. Tim says:
    But the real question is… Does it play crysis?
  8. Anonymous says:
    Certainly a lot better than the stairs I used to draw on those things…
Leave a Reply to Tim Cancel reply
Related Hacks in toy hacks
